Difference in Rolli...
[Closed] Difference in Rolling Radius between 700x23c and 700x25c ?
7 Users
I have limited clearance on my Cube road bike, especially if I am going to fit some road racer guards.
Before I order some replacement tyres Does anyone know the difference in rolling radius between 23c and 25c tyres ?
Conti GP4 Seasons specifically ?
Dom
Posted : 29/08/2013 12:48 pm
Cruds are only for 23c tyres, as far as I can recall.
Posted : 29/08/2013 12:50 pm
I imagine it would be 2mm.
I've fitted Roadracers with 25mm Schwalbe tyres and had no problems.
Posted : 29/08/2013 12:51 pm
Crud RRs were supposed to fit 25s though many seemed to have problems doing this.
The chap in Evans Cycles yesterday insisted that there was no difference. He said the 25mm tyres were 1mm wider on each side than the 23mm ones but didn't stick out any further.
At that point I lost interest in trying to get any worthwhile info from him.
+1
Although itdepends on the rim, my 23mm Ultremos on Stans rims are bigger than the 25mm blizzards on shimano rims.
Crud guards are hatefull things, get some raceblade longs or a winter bike.
Posted : 29/08/2013 12:54 pm
I've just had a look, got 23 + 25mm conti ultras on, both at 100psi, difference in radius is about 2mm
Posted : 29/08/2013 1:12 pm
Not so, I got on fine with mine, much better coverage than any of the other non-mount mudguards. I only stopped using them as I got a frame with proper mounts, so fitted some SKS guards.
Posted : 29/08/2013 1:14 pm
Can't do another bike for winter as its getting close to S-1 time
I wont ride it through winter, but its likely to get wet soon, I have some roadracers.
I also have raceblades on another bike and the calipers still end up absolutely minging 😥
I have 23c ultremo ZX`s on at the moment which both need replacing due to cracking at the edge of the tread / sidewall (oh and theyre cr@p at dealing with tiny pieces of Flint that end up on the roads every time it rains around here)
So it was GP4Seasons to try next but would have liked to have gone to 25's
tadpole - Member
Thanks for that, I knew they were wider but wasn't sure if the Radius changed too
Dom
Posted : 29/08/2013 1:27 pm
