Difference between ...
[Closed] Difference between these forks
4 Users
What is the difference between the Rockshox Revelation RLT Ti Dual position Air 150mm Fork and the Rockshox Revelation XX Dual Position Air 150mm Fork?
Posted : 05/05/2011 11:25 pm
Do a search covered recently I believe.
Something to do with hydraulic lockout on the XX, or some such difference. Also slight weight differences.
Posted : 05/05/2011 11:33 pm
A mate has just had this dilemma. He bought the xx ones. The differences are mainly the remote lock out and threshold adjust on the xx and it has lighter internals. They look very bling in the flesh.
Posted : 06/05/2011 7:34 am
XX has remote lockout and firm, non-adjustable compression damping but you can adjust beginning and end stroke rebound.
RLT Ti trail version doesn't have the remote lock out but you can adjust low speed compression damping. High speed compression and end stroke rebound is factory set but you can adjust beginning stroke rebound.
Basically if you want a trail fork go for the RLT Ti, if you want a long travel race fork go for the XX. Car park opinions say that the RLT Ti is plusher down but the XX is better to pedal up hill and is more forgiving of bad braking technique.
Posted : 06/05/2011 8:40 am
