Dialled Prince Albe...
[Closed] Dialled Prince Albert as a Commuter?
12 Users
Anyone using a Prince Albert as a commuter bike and want to share some pictures, I was going to get a Trek Soho but I am going to space challenged so need to take a current bike and make it a commuter and be able convert it back easily to a XC bike.
I've got a spare set of wheels with the same hubs so can make up a set with slick tyres so that's ok and can get some secure skeweres.
It's the mudguards that I think are an issue or at least feel like an issue as I don't think a crud catcher is where it's at for the front at least, not so worried about panniers as I can get what I need to carry in a rucksack but thoughts welcome.
Any ideas, advice and thoughts welcome, it's going to be a short commute around 2.5 - 3.0 miles.
Posted : 09/01/2010 1:26 pm
Waste of a good bike 🙁
Posted : 09/01/2010 1:32 pm
for 3 miles it will be ok
especially if all you are changing is a set of wheels
Posted : 09/01/2010 1:52 pm
Rob did you misread this bit
Because of where I live it only get's used when I head back to the softer southern trails and the odd Gorrick race so it's the least used bike, so makes sense for it to become dual purpose.
Do need to sort a good front mudguard out though!!
Posted : 09/01/2010 3:00 pm
That's not a bad plan. A spare set of wheels will make the process of swapping them back quite easy. Admittedly not the ideal bike for it, but ok if you have one already...
Those fugly moto-x mudguards would be your best bet. Maybe those neo-guards might work ?
I had conti sport 1.3s on my kona for a while and found that most of the annoying spray comes off the front of the wheel, through the fork, and into your face 🙁
If you want skinny slicks then Conti Sports are great, btw. And you'll need the spare set of wheels cos they can be arkward to fit.
Posted : 09/01/2010 3:11 pm
I'm commuting on mine at the mo, best bike I have for these conditions!
Posted : 09/01/2010 3:20 pm
It wouldn't be my first choice commuter bike if I didn't have it already, it's would be my first choice Steel XC Hardtail I do enjoy taking it for a spin on the trails 🙂
Will look at the fugly guards and the neoprene maybe run both if it's possible, Conti Sports did they offer good puncture resistance?
Posted : 09/01/2010 3:24 pm
The contis had very good puncture resistance.
I maybe did 1500 miles in them or so (not much) and don't recall puncturing them. Which is good, because I'd HATE to have to change the tube on the road! (Real pain to get on/off)
The 'guards are these types : http://www.evanscycles.com/products/topeak/defender-fx-front-ec004905
I hate how they look, but they're probably the best solution.
PS. I'm a Prince Albert owner too, I love the bike for off-road too 🙂
Posted : 09/01/2010 3:30 pm
used to do 14 miles a day on it
Posted : 09/01/2010 3:41 pm
holyhutzpa - Those guards are visually challenging but if they do the job then it will be fine.
PA is a great bike hence I don't want to sell it to buy a proper commuter and for the distance I'll travel happy to make do.
rocketdog - liking that 🙂
Posted : 09/01/2010 3:57 pm
I use mine for a 5 1/2 mile commute quite often but I dont bother changing the tyres, just ride it as it is.
Posted : 09/01/2010 4:38 pm
 jond
Every rigid or HT mtb I've owned, I've commuted on to some degree (2, 12, 9 miles each way depending on work/home location). Just pump the tyres up hard and they're probably roll reasonably well (tho' it might be a waste of an expensive XC tyre, unless you by something that's cheap/will wear well on the road). I can't be arsed with slicks most of the time, got some Contis of some sort and they're an utter git to get on and off, plus some of the commute can be off-road.
Crud catcher's work reasonably well - or at least well enough that I've never worried about fitting anything bigger. So long as you don't mind washing your face when the roads are really crappy, you'll get lots of black freckles 😉
Posted : 09/01/2010 4:53 pm
Use mine to commute into Bristol down the Gloucester Road, then I have the option to commute home via Leigh Woods or Ashton Court - cant be bad. Didnt really have that choice when I commuted on a hybrid for a while. But then I only ride 2 miles to work....
Posted : 09/01/2010 6:42 pm
 dano
Key and jond have got the right idea... for less then 5 miles each way you really dont have to bother about changing tyres and wheels, the extra cost of this is years worth of tyres... i commute this distance nd sometimes swap tyres, otherwise just ride my off road tyres and enjoy the extra grip and try and find off road sections... or just run cheaper tyres like some steel bead, you can get these for about a tenner...
Posted : 09/01/2010 6:51 pm
Good comments appreacite the thoughts, will sort the guards out and give it a go.
Posted : 09/01/2010 7:37 pm
It might be worth trying Crud Catchers with a Neoguard on the forks (between them they'll catch most of the spray, and be slightly better looking than a moto-x guard (imo)
Posted : 09/01/2010 7:54 pm
 DT78
Sport contacts are on offer at £10 each from on-one at the moment. They are a serious pita to get on the rim though. I punctured a few tubes until I managed it.
I've just done the same thing (spare set of wheels for commuting) for my charge.
Posted : 09/01/2010 7:55 pm
commute on mine, i just swap the fork to a rigid and stick slicks on it
Posted : 09/01/2010 7:57 pm
Thanks for the pointer on the tyres they are now ordered 🙂 Great Price.
Posted : 09/01/2010 8:12 pm
 DT78
No worries bargain price, I got some speed kings as well whilst I was at it
I'd recommend leaving the wheels/tyres next to a radiator to warm up before you fit them! Oh and use really skinny inner tubes I found our 2.0 were too big....
Posted : 09/01/2010 8:16 pm
Will do and thanks, also now sorted skewers and a neoprene thing, got some cruds so when it all arrives will create commuter Albert.
Posted : 09/01/2010 8:40 pm
