Does anyone know the size of the bolts/grub screws used to hold the phil wood EBB?
The ones that came with my dialled love/hate are pointed and I want to replace them with cup points to try and make adjustment a bit easier. Currently the points tend to slip into nearby existing dints caused by the points previous engagement.
While we're on the topic of PW EBB - does anyone have a trick/tool for rotating and holding the EBB body in the shell whilst they tighten the bolts?
Not sure on the size of grub screws but the pw ebb on my Swift accepts a 6mm allen key into the non drive side for adjustment
Speak to the man at Sideways Cycles.
i used to hold the BB with a BB spanner, I can't remember which side now, but 1 side will tighten the bb, and rotate the EBB so you can tighten it
