Di2 Road STI mixed ...
[Closed] Di2 Road STI mixed with MTB 1x11
4 Users
I just impulse bought a pair of Di2 STI's (R785) as the price was too good to pass on.
What I would like to do is combine it with a MTB rear derailleur and 11-42t cassette for use as a gravel drive train.
I've heard tell that this is possible but have no idea about what to combine and all the other Di2 bits n bobs required.
Anyone had success in this area, if so, what did you use??
Update* I see the specialised diverge s-works uses this rig, so that provides me with the majority of my shopping list (unless you can think of better pairings) but what do I need to hook it all together??
ref:  https://road.cc/content/buyers-guide/237160-23-road-gravel-and-cyclocross-bikes-1x-gearing-%E2%80%93-can-one-chainring-do-it
Posted : 09/11/2018 11:39 am
Yep. easy.
You'll need MTB mech, a battery, a junction box A (stem), junction box b (bottom bracket) and 5 wires of the correct length and a charger.
Posted : 09/11/2018 2:42 pm
Have a look at the Pinnacle Arkose LTD, that was a 1x XT Di2 set up.
Posted : 09/11/2018 9:03 pm
I’m using the same levers (r785) with XT Di2 rear mech, 11/40 rear cassette and 42t superstar front ring.
I’m using the XT m800 display/junction as well at the moment, although I’ve also used the normal 5 port under stem junction
No problems to report, you have to select mtb on the e tube software to update it not road, but you have to update the m800 junction by Bluetooth
ive done 6 cx races on it this season as well as training rides and can definitely recommend it
Posted : 09/11/2018 9:38 pm
Good to know - it sounds great in theory...
Do you run it with one shifter changing down and the other changing up??
Posted : 09/11/2018 11:45 pm
I did try it, but as I also have road bikes with Di2 I changed it back to keep them the same.
Posted : 10/11/2018 7:13 am
I have my left and right shifters set up so they both do the same thing on 1x. Small button down, big up.
Posted : 10/11/2018 7:20 am
