Di2 Hacking.
[Closed] Di2 Hacking.
11 Users
I've just finished building this.
I can now change gears using my phone 😀
Posted : 05/09/2015 5:47 pm
Very cool, although I'm not entirely sure why one would want to do such a thing 😆
We need more details though!
Cheers, Rich
Posted : 05/09/2015 5:50 pm
go on then, more details,
Posted : 05/09/2015 5:52 pm
I dare you, no, I DOUBLE dare you, to set things up so that it tweets your location whenever you change into the granny ring.
Posted : 05/09/2015 5:56 pm
Nice.
Just needs some voice activation now.
Posted : 05/09/2015 5:57 pm
Are you able to change someone else's gears from your phone?
Posted : 05/09/2015 5:58 pm
Everyone needs an app to change gears 🙂
It's part of a bigger plan where the phone app also reads power from a stages power meter, compares the output of the meter with a target power and then select a higher or lower gear to try and match that.
The idea being during say intervals or best power profile over a route, you just pedal at the cadence you want, the phone makes sure you're putting out the appropriate power.
Only if I throw the phone at their gear shifters or discretely plug the unit in when they're not looking :),
Posted : 05/09/2015 6:01 pm
From a totally geeky perspective - this is very cool. Please share more info - how, etc?
Love the idea!!
Posted : 05/09/2015 6:03 pm
like this?
http://lavamagazine.com/proshift/
Posted : 05/09/2015 6:06 pm
Fairly easy. I've looked at the actual Di2 comms protocol in the past and decided it was too complicated to reverse engineer, so instead took the guts out of a DI2 satellite shifter and connected it to this http://www.rfduino.com/product/rfd22301-rfduino-ble-smt/index.html
which has been programmed to emulate the buttons being pressed over a bluetooth low energy connection. The biggest problem was getting the thing to drop down to a low enough current consumption when not in use that it wouldn't drain the battery - so there's also a movement sensor in the box to solve that.
Posted : 05/09/2015 6:10 pm
Interesting!!
Posted : 05/09/2015 6:11 pm
like this?
yup, but in theory better as it will use location based information from the phone to choose the power level. The proshift is using a preset power range, but for best speed for a given power budget you want something which selects different power levels for different gradients.
In theory you should be able to uploaded a power plan from say bestbikesplit.com onto onedrive, and the phone will then just follow it.
Posted : 05/09/2015 6:16 pm
thats awesome 😀
Posted : 05/09/2015 7:21 pm
"Siri, change down two gears".
And at 1439 it became self aware and in a panic Ian Munro changed gear first, Di2NET struck back, 52:11 on a 25% climb was very messy.....
Posted : 05/09/2015 7:26 pm
Posted : 05/09/2015 7:29 pm
