DH Wheelset - Nukep...
[Closed] DH Wheelset - Nukeproof vs Hope
5 Users
£250 budget to get me some DH wheels. I'm thinking either:
Nukeproof Generators OR
Hope Hoops - Pro 2's on Mavic 721's
Rear needs to be 150mm / 12mm
Front needs to be compatible for Boxxers - is that 20mm?
Any thoughts / advice?
Thanks
Posted : 30/07/2010 7:50 am
i've got a Nukeproof hubs on 719 rims, and a Hope Pro2's on 721's.
the only difference you'll notice* is that the rear nukeproof hub is a little cheaper, and a little quieter, than the rear Hope hub.
(*without taking them apart)
all the hubs are the same weight - to within a few grams.
yes, Boxxers are 20mm.
Posted : 30/07/2010 7:59 am
Thanks. No probs with the Nukeproof hubs? Have heard of a couple of freehub problems
Posted : 30/07/2010 12:06 pm
Boxxers are 20mm axles, and the new axle works really nicely.
I'm running a 150mm Hope on my DH bike and it has been faultless (so far).
Posted : 30/07/2010 12:09 pm
Hasn't there been problems with Hope axles snapping with non-QR axles?
IIRC there was a thread about it happening with Maxle rear ends on Hope hubs, put it that way.....
my nukeproof and hope hubs have been faultless.
if i had to buy another wheel, i'd probably get... er... another... Nukeproof - it's just a bit quieter than a pro2.
Posted : 30/07/2010 12:45 pm
No the problem with hope axles snapping is with the new maxle light. Not the standard maxle or the standard bolt through nor are their with the front
Posted : 30/07/2010 12:56 pm
