Anyone happen to know the brake pad code for Shimano ice tech pads that will fit 2015 deore brakes (br m615)? Details seem a bit shaky on the usual online sources. Normally I'd ask the lbs but can't get there for another week.
I'm a heavy blighter and the ones in there seem to be the first set of brakes I've never cooked so I'm prepared to cough up for these over standard.
Y8KA98010 Resin Pad (G01S) & Spring w/Split Pin
Y8JZ98020 Metal Pad (G03S) & Spring w/Split Pin
Edit: Ah, they're not ice tech ones, just the standard. Think it's SLX and above that come with those...
Y8J79801A Resin Pad (F01A) w/Fin & Spring w/Split Pin
Y8J79802A Metal Pad (F03C) w/Fin & Spring w/Split Pin
Perfect thanks. 😀
Here you go.Shimano tech page.[url= http://www.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/BR/EV-BR-M675-R-3286_v1_m56577569830800233.pdf ]link[/url]
