Deore 11-51 rear ca...
[Closed] Deore 11-51 rear cassette: Rattling like a rattling thing
12 Users
I had problems with rattling SunRace - but now fitted to a spare wheel , on the same free hub body and it is fine.
Bought new steel free hub for my normal wheels ( hope pro 4 hubs) - and a Deore 11-51 rear cassette - which now rattles like a bastard. It's no loose on the free body (like the sun race) but the alloy spider attaching the big cogs seems to have loads of play in it!
Is that normal - and get used to it buster - or do I have a set of Friday afternoon rear cogs?
Thanks
Posted : 05/03/2021 2:16 pm
If its 11spd, you'll need the spacer before the cassette on a hope hub, but you'll know that I'm sure
Posted : 05/03/2021 2:44 pm
 LAT
there was an issue where some of the sprockets came loose at the rivets. this was on the 11 speed
Posted : 05/03/2021 3:28 pm
It’s 11 speed, they are very , very loose. And yes I have spacer in place
Posted : 05/03/2021 8:39 pm
Can you see if there is movement where the rivets are?
Posted : 05/03/2021 9:02 pm
Mine did that. Replaced under warranty.
Posted : 05/03/2021 10:41 pm
Rivets loose on mine too, replaced by madison
Posted : 06/03/2021 8:45 am
I had heard of AliExpress rivets coming loose (mine still solid so far) but not Shimano till now. I might need to look at the fully machined ones if the rivets fall out of mine.
Posted : 06/03/2021 9:29 am
I can't help you with the tech. question, but the simile for rattling is "like a skeleton w*nking in a biscuit tin".
APF 🙂
Posted : 06/03/2021 12:04 pm
spotted that mine was doing this yesterday, rivets really loose, I've emailed the seller buts its in Germany so expecting some fun there, sure a spot of weld will fix it but a replacement should be the solution, its only 5 months old....
Posted : 06/03/2021 12:47 pm
Okay - so,I am not alone then. All I have to do is remember where I bought it from
Ah - bought from Bikester - so that’s where the problems will begin.
Posted : 06/03/2021 4:46 pm
Mine came from bike-discount.de but that was pre brexit so I'm anticipating trouble especially if they want it back!!!, apparently any Shimano dealer can do the warranty claim but don't feel comfortable with that due to not purchasing there....
Posted : 06/03/2021 4:51 pm
 icic
I bought a replacement, as I'm not sure it is worth the hassle of sending back to Germany 🤔
My issue being the loose rivets as per this Reddit post - Not by me.
Reddit - MTB - Shimano Deore 11 speed 11-51 loose, anyone else had this? bike is only couple of months old https://www.reddit.com/r/MTB/comments/jvwtqn/shimano_deore_11_speed_1151_loose_anyone_else_had/
Posted : 06/03/2021 4:56 pm
^ thanks ICIC
That is exactly the issue ...
Just sent a email to Bikster - post Brexit may be a challenge - but I guess they could refund.
Posted : 06/03/2021 6:01 pm
@alexpalacefan thanks for a LOL here.
Posted : 06/03/2021 8:41 pm
See also post by "huckleberry hound" here:
https://www.mtbr.com/threads/shimano-m5100-11-51-11-speed-cassette.1145945/page-6#post-15073577
The alloy spider unit is loose on some freehub splines, he packs it out.
Posted : 06/03/2021 9:58 pm
It I’d the spider to cogs connection that is the issue. Thanks for the above - but way too much faff
Posted : 07/03/2021 9:12 am
Any luck with this?
Mine has the same problem now, spider rivers loose!
Got mine from AliExpress, wish me luck
Posted : 01/04/2021 2:49 pm
I got a rebate from Bikester - I am not sure it was the full amount I paid but I got around 55 quid back. TBH , I thought I was going to get nothing.
That said I have bastardized the cassette and used the smaller cogs on my other bike ...
Basically Shimano has an issue with build quality
Posted : 01/04/2021 6:10 pm
I shoulda bought an aliexpress cheapie, thought I was buying quality! Mine was £38
Posted : 01/04/2021 9:28 pm
