Darkside content......
[Closed] Darkside content..... Loose cassette on Askium wheel?
7 Users
Hi all.
I bought a set of unused but secondhand Mavic Askium wheels and have tried to fit a new 105 cassette to them but even with the lockring up tight the cassette is still loose?
There was a spacer that come with the cassette that I fitted but its still wobbly?
10 speed cassette if it helps.
Have I done something wrong?
thanks
Steve
Posted : 08/02/2018 11:17 am
10 speed needs a wider spacer than 11 speed. Think I fit two to my Ksyriums./
Posted : 08/02/2018 11:23 am
Will need a spacer for 10speed I would think.
Have you checked the actual freehub itself isn't wobbly? Movement of the cassette will accentuate any wobble, but I had to send back a Ksyrium because the freehub went wobbly after only a couple of hundred miles.
Posted : 08/02/2018 11:32 am
Think this is what you need;
http://www.chainreactioncycles.com/mavic-cassette-spacer/rp-prod25399#
It sorted it for me when I switched from a 9 speed cassette to a 10.
Posted : 08/02/2018 11:52 am
Hopefully some one will have a correct answer just from memory Mrs antigee had 10 speed mavic askiums and the hub is a bit unusual doesn't follow normal 10 11 speed spacer rules and needs 2 spacers the thin one and the slightly thicker one sorry to be vague but you are right it does need some effort to sort
Posted : 08/02/2018 12:02 pm
You need the 1mm spacer that comes with the cassette and a 1.85mm 11spd spacer.
Posted : 08/02/2018 12:17 pm
What everyone else said.
Posted : 08/02/2018 12:48 pm
Ah right that makes sense.
Thanks for the help !!
Posted : 08/02/2018 2:51 pm
