Damaged wheel advic...
[Closed] Damaged wheel advice please
4 Users
hi , nothing too serious but I have a couple of dings on my rear rim and also a bent spoke .
Can I just bend the rim out a little with pliers? Doesn't seem to be a problem for tubeless inflation but now have two in roughly the same spot? Coincidence?
Also, the spoke... Should I just tighten it a little? Replace? Is it a sign of weakness somewhere else on the wheel?
Thanks all!
[URL= http://imagizer.imageshack.us/v2/150x100q90/913/k8t3Ok.jp g" target="_blank">http://imagizer.imageshack.us/v2/150x100q90/913/k8t3Ok.jp g"/> [/IMG][/URL]
[URL= http://imagizer.imageshack.us/v2/150x100q90/913/TVV8Yh.jp g" target="_blank">http://imagizer.imageshack.us/v2/150x100q90/913/TVV8Yh.jp g"/> [/IMG][/URL]
Posted : 30/12/2014 9:37 am
Tis but a flesh wound.
If that was mine I'd straighten it when I had the time. I'd only tighten the spoke if the wheel needed truing, even with a kink it's still exerting force.
Some people are more precious than me though.
Posted : 30/12/2014 9:45 am
Thanks for the reply . The spoke is quite loose too
Posted : 30/12/2014 10:12 am
 nach
I'd probably replace a spoke that's that kinked. Ideally you want all of the spokes taking some load rather than others compensating for a loose one, but if you've flattened a part of the rim that might be tricky.
The ding is probably fine, but if you use a tool to straighten it, bear in mind you won't get it perfect, and protect the surface of the rim with something like a rag or some rubber.
Posted : 30/12/2014 10:20 am
 tomd
I wouldn't bother straightening the ding if the tyre still seats properly, there's a chance it'll crack when you try and straighten it and it won't make it any stronger.
Posted : 30/12/2014 2:45 pm
