CX Tyres on a road ...
[Closed] CX Tyres on a road bike - what size is OK?
3 Users
I want to turn my old steel ss road bike into more of a all rounder and would like a tyre with a bit more grip (than a slick) for farm lanes, forest fireroads, dry singletrack, that sort of thing.
Not worried about 'mud' clearance as it won't get use in the thick stuff.
Seen some Schwalbe CX Comps for a tenner each that are 700 x 30 and want to know if they would likely fit?
Posted : 10/03/2011 9:42 am
Depends entirely on the frame. What's the biggest tyre you could try now - is there much extra space?
Posted : 10/03/2011 9:57 am
They are 700 x 23c at the moment, the brakes are the biggest issue but there is plenty left and right clearance but not a huge amount above the tyre before the brake.
Posted : 10/03/2011 10:07 am
I've got 700x30 CX Comps on the Kaffenback. There's only a couple of mm clearance at most between the edge of the knobbles and the chainstays, although like you I'm not planning on using them anywhere properly muddy so this shouldn't be a problem. So far they've been great on hardpack, farm tracks, country lanes awash with bovine by-products, and cyclepaths covered in gloopy mulch.
Probably of more interest to you, they're 28mm high (measured from the top of the rim).
HTH
Posted : 10/03/2011 11:47 am
Thanks Tony_M thats the useful comment that can make this forum great!
I will measure tonight and check the actual height of my rim and brake and see if 28mm is enough.
Posted : 10/03/2011 12:00 pm
