cushcore bead dropp...
cushcore bead dropper tool..........
12 Users
does the bead dropper tool really help to get tyres off with rimpact/cushcore?
its a real nightmare (and wrecks my wrists/hands) to break the bead even on a bin with just a tyre lever, i eventually get there but its damn awful my arms wreck for days later
so given its 20 quid i dont want waste money if its actually no better at removing the bead?
some one please tell me it makes the job 100% easier with the tool please
Posted : 05/09/2022 11:10 am
 feed
I just put the wheel "flat" on the ground, stand on the tyre on one side, then put my foot on the tyre at the opposite side and apply a sharp downward force. Can take a few sharp downward pushes of the foot but never fails to break the bead and hasn't damaged \ buckled the wheel ( yet 🙂 ).
Assuming you're talking about the cushcore bead dropper tyre levers, all they are is very strong tyre levers. They are a great help for getting tyres on with inserts but they don't offer help for breaking the bead part of removing tyres. They're very good for getting tyres on the wheels and in my opinion worth the money as they won't damage the rims unlike steel DH levers. I did actually manage to break one 5 days ago 🙁
Posted : 05/09/2022 11:45 am
suppose i could do that on the grass - wouldnt want to do it on the concrete floor and ruin my wheel though ha!
ive always managed to do it - but its a pain and not always smooth espeially when in a rush lol
Posted : 05/09/2022 11:48 am
 feed
suppose i could do that on the grass – wouldnt want to do it on the concrete floor and ruin my wheel though ha!
I do it on a concrete floor with a small piece of flat wood (or plastic) under the hub.
Posted : 05/09/2022 11:57 am
good call - i could get a piece of wood no problem from work
if anyones actually used the tool though please report how much easier it is please?
Posted : 05/09/2022 12:04 pm
Not easy, but at least possible. I used the kneeling on the lawn position, then used the bead dropper in a stabbing motion to break the bead and push it under the insert. Initial break was the hardest but the tool definitely makes it easier to push the bead under the insert. Once you done that most of the way round it gives enough slack to remove the tyre easily.
Posted : 05/09/2022 1:16 pm
I'd say they're useful, they have a much better grip than a normal tyre lever but there are better ways to break the bead as above.
Posted : 05/09/2022 1:17 pm
ok thanks folks - so not the holy grail of a quick removal i was hoping for, just basically helps in addition to the above - hardest part is gripping a standard tyre lever to push down on the bead
Posted : 05/09/2022 1:33 pm
I fitted my cushcore (and removed it several times to reseat a leaky valve) over the weekend. I found the easiest way to get tyres on and off was to wrap a towel around tyre and just roll the far side of the tyre off the rim towards me, rotate tyre and repeat.
Getting the bead into the wheel well was done by holding the wheel perpendicular and vertical to me, flattening the tyre, pushing it to the far side of the rim, then rolling the tyre/cushcore back towards me, and pushing the bead down into the well with fingers. Then just work your way around the tyre until its all in the middle. Using a towel helps you to grip the tyre and not end up with sealant-y hands.
Using the above method I fitted, removed and refitted the tyres probably 4 times in 45 mins. No tyre levers necessary.
If that makes no sense, dm me and I might be able to make a quick video demonstration.
Posted : 05/09/2022 1:49 pm
I have an old light bicycle rim and the only way I can pop the bead with the rimpact inserted is with a garden spade!
Posted : 05/09/2022 3:28 pm
😀 They are extremely good at keeping a bead in place aren’t they. Not resorted to a garden spade yet but I can imagine doing so if there were one within arms reach
Posted : 05/09/2022 10:09 pm
This worked for me, though I did wear a thick gardening glove to spread the pain
Soapy water !
Posted : 05/09/2022 10:25 pm
Put your tyre lever in a old grip and save yourself 20 quid.
Posted : 06/09/2022 5:48 am
The bead dropper is much more for getting tyres on than off and for that it's extremely useful. I still find removal is an absolute b*stard sometimes, depending on tyre/rim combo. A bench vice on the tyre has worked for me in the past when things have been terminal. The stand on it technique never works for me when I have an insert in.
Posted : 06/09/2022 8:31 am
I wander how long it'll be before someone adapts a Rabaconda for MTB use.
https://rabaconda.com/
Posted : 06/09/2022 8:56 am
OK, you know I'm gonna try this now. Better not be a joke.
Posted : 06/09/2022 2:13 pm
