Current 27.5" ...
[Closed] Current 27.5" revs... can you change travel on them?
3 Users
Does anyone know if you can increase the travel on a 27.5" 130mm RL?
I know with the pikes you can just buy the internals and swap it over to make them into a longer travel model but not sure if this is the same with the revelations?
Anyone know the answer and part numbers for the bits needed
cheers
Posted : 18/07/2014 11:14 pm
 LoCo
Yes, just swap air shafts, £35
Posted : 18/07/2014 11:45 pm
awesome, cheers.
Posted : 18/07/2014 11:56 pm
Did it just last week on a 120. Air spring shaft bought £25 (not the kit) lowers off, 15 mins later 150mm 🙂
Posted : 19/07/2014 12:04 am
good to know it was nice and easy.
Could have just found out in work on Monday, but sat here deciding which bike to buy and making a list of all the things to change as soon as I get it because it is far to hot and humid to sleep!
Posted : 19/07/2014 12:07 am
Yes suprised myself. You do need a snap ring tool, oil and grease as well. Do a search for rock shox revelation 2013 manual for a quick read, it says to remove the top of the fork shaft but I didn't.
Posted : 19/07/2014 12:38 am
