Xfusion dropper sea...
[Closed] Xfusion dropper seat angle adjustment?
6 Users
Hi I'm having to borrow a mates old bike for a weekend trip as my new frame hasn't arrived..boo hoo
It has an old x fusion lever dropper and I need to lift the nose a bit. Undo the one bolt that holds outer plates retaining the saddle rails on the shaped inner rails. But when you take this apart I can see no way to move inner plates thus adjusting angle?
Anyone recognise this set up and know what to do.
Posted : 01/10/2014 7:50 pm
 jimw
Edit:
wrong post!!
Very sorry, got confused between my Giant and x-fusion posts, original reply was for the giant
Posted : 01/10/2014 8:07 pm
Ok thanks will have a play
Posted : 01/10/2014 8:10 pm
Unless it's seized for some reason, you just need to loosen the bolt (not take it out) and the saddle will tilt up and down fairly easily. The problem I had with mine was getting the bolt done up tight enough afterwards to stop it moving about while sat on it.
Posted : 01/10/2014 8:15 pm
The tend to seize up a tiny bit, once the bolt is out, stick a screwdriver through the bolt hole so it rests on the opposite face, and give it a tap, should release it.
Posted : 01/10/2014 8:30 pm
If I remember correctly, the inner plates of mine stuck onto the central bit and needed a screwdriver to pry them off to allow movement.
Posted : 01/10/2014 8:34 pm
The xfusion manual suggest using some grip paste non slip stuff to stop the rotation but it does seem to stick the plates into the body a bit. Make sure both sides are free, saddles a bit uncomfortable when they get twisted
Posted : 01/10/2014 11:02 pm
