Crud Road Racer Mk2...
[Closed] Crud Road Racer Mk2 on a cross bike?
8 Users
Any one tried them on 32mm tyres?
Road CC say they are a bit fragile. I'll mostly be using them on tow paths and Sustrans routes, so they are just to keep water off me really, but I wouldn't want something that breaks if I do get it packed with mud.
Posted : 02/11/2014 9:03 am
If you have them already the go for it.
I wouldn't choose them over the sks ones.
Posted : 02/11/2014 9:16 am
Biggest they'll cover is 25mm & you need a caliper to attach them too.
If you're looking for guards that'll attach to a frame without mounts, try Axiom axle runners.
Posted : 02/11/2014 9:22 am
I couldn't make them clear 25mn, had to put 23s back on. Even then the slightest thing on the tyre and they're grinding away.
Wiggle have the zefal croozer/swan pack for under a tenner. They're like a thinner version of most MTB guards - I got a set for when I inevitably get fed up with the roadracers.
Posted : 02/11/2014 9:45 am
Roadracers worked fine on my road bike with 28s
Planet X are doing some Vavert guards for about £13. Look very good - planning on picking up a set
Posted : 02/11/2014 9:46 am
The set I had fell apart. The heads on the little plastic screw things seem to break off very easily.
Posted : 02/11/2014 10:06 am
I can't get mine to fit 25mm Aksiums without letting some air out so clearance must be in thou.
Posted : 02/11/2014 10:09 am
I use the Zefals above. They are great although the rubber straps perish quickly (I use the rubber bands from a crud guard). Do a decent job of keeping me dry although not much use in a group as guy behind gets soaked from rear wheel !
Posted : 02/11/2014 10:33 am
Thanks for the various suggestions.
Those Zefals look good, except that I would prefer something that extends forward of the fork to keep the spray off my face.
The [url= http://www.chainreactioncycles.com/sks-beavertail-mudguard-xl-set/rp-prod34474 ]SKS Beavertail[/url] looks like it would do a better job for not much more money.
Posted : 02/11/2014 10:56 pm
