Crown race (not) fi...
[Closed] Crown race (not) fitting
4 Users
Should there ever be a gap between the crown race and the bottom of the fork steerer tube? Been trying to fit a cane creek reducer crown race to fox talas forks and there's about 5mm to go. Won't go beyond that point (I'm using a proper crown race fitting tool). Wondering if the crown race reducer has been manufactured too small!
Posted : 23/06/2012 8:34 am
Cut a slot through it with a hacksaw, then it'll fit.
Posted : 23/06/2012 8:35 am
no it should fit all the way down, did you grease it ?
Posted : 23/06/2012 8:43 am
Problem with cutting a slot in it is that the rubber seal is attached to the crown race.
I did grease it.
Thanks for your replies.
Posted : 23/06/2012 8:50 am
any pics of the crown race??
Posted : 23/06/2012 9:04 am
It's one of these: http://www.thebikefactory.co.uk/productdetails.asp?productid=56993
Posted : 23/06/2012 9:59 am
crown race in a mug of BOILING water.
bit of grease on lower flared part of steerer.
length of PVC waste piping,
drive it on. POP.
Posted : 23/06/2012 10:30 am
