Crossmax ST QR adap...
[Closed] Crossmax ST QR adapters
6 Users
Does anyone know where I could get hold of 9mm QR adapters for a front Mavic Crossmax ST?
The usual google search hasn't come up with much. Short of going to my lbs I thought I would ask on here as they aren't open on a Saturday evening 😆
Gordymac
Posted : 16/02/2013 6:51 pm
You can for the 2012/2013 model years, not sure about earlier ones.
Posted : 16/02/2013 6:53 pm
Pretty sure I have some int the shed I can let you have for postage, can check tomorrow for you, PM me and I'll let you know in the morning
Posted : 16/02/2013 7:05 pm
Hi Stu
Ygm
Gordymac
Posted : 16/02/2013 7:25 pm
Let us know if it falls thru.. saves me going down to the shed hunting fur things ;O) Pretty sure there's a pair in a bag somewhere.
Posted : 16/02/2013 7:32 pm
Ok so I'll come out of this with what I need hopefully. Thanks guys.
Martin I sent you a text earlier. Maybe I should be asking you what you think of the Crossmax ST first of all?
Gordymac
Posted : 16/02/2013 7:39 pm
Aye, I replied about 40 mins ago. I have 2009 st's and I would buy another pair again. Fast,stiff,hassle free apart from the occasional hub tweak at the rear.Never had to replace bearings, never powerwash them (hardly clean them at all) and only serviced the pawls etc twice. They are on a 2nd bike and have been used over each winter from around 2010. I bought them 2nd hand but were as new when I got them. The rims seem as tough as your 819's. Mavic is quality in that sense as you know.
Like I said to Ewan earlier, I don't ride as much as yoursels so.. ;O)
Posted : 16/02/2013 7:57 pm
Ok sounds good to me.
I've not had anything back from you yet. It must be lost in cyberspace.
Gordymac
Posted : 16/02/2013 8:18 pm
Gordymac,
Found my adapters but they were from crossmax sx wheels so are 20mm any good? or do you need 15mm?
Posted : 17/02/2013 6:19 pm
Hi stufield
To be honest I'm not sure if they are 15 or 20mm. I'll check and give you a shout if its 20mm.
Gordymac
Posted : 17/02/2013 8:08 pm
I have a set of 2009/10 crossmax st's - they're 9mm QR, reading this, does this mean I can swap the hubs to 15/20mm thru axle?
Posted : 17/02/2013 8:44 pm
I have a set here too... I use the Bolt through stuff...
Never used the Q/r option...
Posted : 17/02/2013 9:10 pm
