cross brakes bodge ...
[Closed] cross brakes bodge needed
9 Users
just put new pads in my cross brakes, they were a bit loose when in place but popped the wheel in anyway and they just fell out. they only seem a shade too narrow in the channel-any bodges to make it work or do i need to find some that actually fit?
ta
Posted : 24/01/2010 10:43 am
You probably have campag fit ones instead of shimango ones
Posted : 24/01/2010 2:53 pm
Bodge brakes? No thanks, they are the one thing I like to know are working properly.
Posted : 24/01/2010 4:21 pm
pretty sure they're not campag fit, these [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=35458 ]ones[/url]
Mister P, not so much after I complained about cross brakes being rubbish* and was shot down by all the race bods
*and if they're rubbish anyway no great loss
Posted : 24/01/2010 7:05 pm
anyone? just normal shimano br550 brakes
Posted : 24/01/2010 7:54 pm
Just for reference, I've NEVER come across a set of pads that were "a bit loose" when fitting. I've always found the refill pads a good fit and require a slight to firm push to slide them in. No experience with Clarks pads though, maybe they have a QC issue? Also, normally there is a little split pin type thingy that locks the pads to the holder, even if the pads were loose this should stop them falling out completely.
Posted : 24/01/2010 9:19 pm
yeah pins were in, im a bit confused too but ill have another bash during the week
Posted : 24/01/2010 10:00 pm
Are they Avid brakes?
Posted : 24/01/2010 10:36 pm
Superglue the ****ers in there, and replace the whole lot next time round?
Posted : 24/01/2010 10:41 pm
no shimano
id rather buy another set of pads now than fork out for brakes further down the line!
Posted : 24/01/2010 10:45 pm
"you must have modified your brakes"*
this response to brake pad problems is ©super-star components
used when i complained that i had to drill out the holes on some pads and had the cheek to suggest they may have a quality problem
Posted : 24/01/2010 10:48 pm
Ditch them and buy more new pads.
Posted : 24/01/2010 11:07 pm
yeah the prob now is which pads and how i know they're wide enough, there was nothing to suggest the clarks wouldnt fit 🙁
Posted : 25/01/2010 9:06 am
dude, iv just replaced my pads with the [url= http://www.wiggle.co.uk/p/cycle/7/Kool_Stop_V-Brake_Standard_Compound_Pair_Of_Inserts/5300003396/ ]koolstop ones[/url], they were a VERY tight fit. might be an idea to investigate them?
Posted : 25/01/2010 9:40 am
Isn't this what LBS's are for, take your bike and the current pads...look at the pads on offer, pick ones that look like they'll fit. Try them there and then! 🙂
Posted : 25/01/2010 10:02 am
yeah that was the first port of call, they werent sure...
not all lbs' are created equal
Posted : 25/01/2010 2:40 pm
