Croix de Fer questi...
[Closed] Croix de Fer question
5 Users
Asking on behalf of an aquaintance.
Would an MTB groupset including discs fit on the above, if fitted with flat bars.
Posted : 22/02/2011 12:59 pm
Can't see why not. It has disc mounts and 135mm rear hub spacing which is all that matters I think.
Posted : 22/02/2011 1:18 pm
I can't see why it wouldn't. Rear spacing is 135mm so the MTB hub will fit. They are a band on front mech so that is fine too. I may be missing something obvious. If it hits me I will let you know.
Posted : 22/02/2011 1:20 pm
 Aidy
It should be fine, but I can't see why you'd want to.
It's got too short a top tube to be run sensibly with flat bars, surely?
I'd've thought the Roadrat in the long variant would have been a better bet.
Posted : 22/02/2011 1:33 pm
Not sure what the ride position would be like with flat bars though. Also, would you get chain line issues running a triple?
It is worth noting that there is very little clearance for a knobbly on the back - even the supplied cx tyres are so close I can make them rub on the frame when I stamp on the power!
Posted : 22/02/2011 1:34 pm
