Creaky Swapouts on ...
[Closed] Creaky Swapouts on Scandal 29
4 Users
Got a 29 Scandal new last week. The swap out/dropouts have been creaking. Turns out the female bolts are slightly too long, new ones are being sent.
However, has anyone had this problem and how did they solve it?
I am going to take them out, clean, refit dry. Hva considered a light spread of dry wax lube over the mating surfaces.
Any thoughts on the bolts, can you get stronger ones?
Apart from that great bike, just need some lighter tyres for the summer.
Posted : 23/07/2013 9:32 am
Could do without this,as I'm trying to think of reasons why I don't want/need one.........
Hold fire on that,I think summer's just ended mate.............
Posted : 23/07/2013 9:36 am
I put a light smear of grease on the mating surfaces and threadlock on the bolt threads and haven't had any noises.
Posted : 23/07/2013 9:37 am
Cheers for the replies already!
Summers still here and its fast, but loose. What tyres are people using, very tempted by some Crossmarks, have a 26 pair and they are very very fast.
Any thoughts on longevity of the bolts, think I will be checking them quite often..
Posted : 23/07/2013 9:41 am
29" tyres - I'm very happy with Ralphs on the Anthem & Inbred...
Posted : 23/07/2013 9:43 am
Well, they've not come loose yet. *runs off to check*
Those Geax Sugauro 29er things that On-one are knocking out are pretty good. Nod idea on weight v racier tread but they've been good in the dry and I can see them not leaving me scrabbling for grip after a summer shower.
Posted : 23/07/2013 9:44 am
the issue with the dropouts is the hole is drilled too deep, the fix is to put a thin split washer in
loads of people, myself included, have the same issue - *simple thing would be for on-one to check the frames and supply washer if necessary, it's a cheap frame so most people would be happy to have this simple fix
(*instead of ignore, and leave their customers to work this out for themselves)
Posted : 23/07/2013 10:33 am
Hmmm yeah like checking when they are being built up.....?
i really like On One and what they stand for but this is a bit iffy, especially if you were not clued up about it.
The whole mount could fall off and cause an accident.
I say this as a friend is still in hospital after 3 days with a fractured vertebrae, after stacking it on Sunday whilst were riding on its first big ride. This was more user error i must add.
Posted : 23/07/2013 12:21 pm
captain, what size washer did you use, I gotta go to Screwfix to get some thread lock.
Posted : 23/07/2013 12:22 pm
[i]I say this as a friend is still in hospital after 3 days with a fractured vertebrae, after stacking it on Sunday whilst were riding on its first big ride.[/i]
his drop out fell off?
Posted : 23/07/2013 12:25 pm
no, he landed on his head at 27 mph, so I am mindful of what can happen.
the issue is if the bolts are assembled and shipped with a known fault, ie the female bolts are too long to prevent adequate tightening then its very iffy.
the forces generated through braking and the chain etc will in time cause a failure if not assembled correctly
Posted : 23/07/2013 12:33 pm
just reassembled, it all, looks like there may be some truth in the short female bolt. swapped it all round and that bolt is spinning abit freely.
anyhow new bolts coming soon, if it dont work out i will send the bike back!
Posted : 23/07/2013 3:36 pm
a little brass split one i found lurking in bottom of tool box
That's cos the hole it sits in is drilled a tiny bit to deep so the bolt doesn't bottom out and instead spins merrily around - shorter bolt or said washer is the fix
Posted : 23/07/2013 3:51 pm
Ok, cheers. Will wait for new bolt.
Interesting to see how the swap outs flex when brake is pulled when spinning wheel, compared to my 26 er Scandal which has a traditional mount. No flex but you can almost see the forces go through the frame.
Also the ride between the two is so different, hard to explain, buts ones nimble and quick the other fast and sure footed. Enjoying both.
Posted : 23/07/2013 5:17 pm
Well new bolts and swap outs are on the way.... Hopefully on Friday.
If you use a shorter bolt, surely this could cause a failure as there will not be the strength provided by the full insertion.
Any ideas on the strongest bolt you could use, ie solid?
Posted : 25/07/2013 1:35 pm
