just trying to use a friends code (may18) for 10% off £99 spend any ideas?,
i want some brendog pedals
signed in and £100 in basket
brands dont seem to be excluded
"<b>You do not qualify for this promotion – please check Ts&Cs"</b>
Maybe the code is tied to your friends email address?
i've used his codes before on my second CRC email account, wondering if my address is marked :0)
as only one code per account per month works
Like these?
https://www.evanscycles.com/dmr-brendog-vault-pedals-EV183951
EDIT: Soz, thought you were saying they were £100 on CRC, not the case
Did you add the code prior to login? If so that screws the code up.
In the past if I've entered the code and then logged in to my account to complete the checkout process it will come up with an error as it thinks the code has already been used. A live chat with customer service got it sorted. Now I make sure I log in before I apply the code.
It worked fine yesterday
To echo others, you get to apply the code exactly once. If you don't checkout there and then, get redirected to login, or edit your basket, the code is gone and cannot be used again. BC will issue you a new one, but this takes time and can be annoying!
I have never got it to work, grrrrr.
