Crankset / frame co...
[Closed] Crankset / frame compatibility
3 Users
Help please:(
I have a 73mm width bottom bracket shell.
30mm hope external bottom bracket
xo crankset bb30 crankset which has a 100mm axle
Using no spaces I believe this isn’t long enough.
What length axle is needed to use with this bottom bracket?
Posted : 05/09/2018 9:15 pm
I reckon (based on this) you’re looking at around 135mm.  BB30 is a pressfit standard and quite skinny.   What you have there is BSA 30 in a standard 73mm shell.
Posted : 06/09/2018 2:31 am
Is your frame BB shell threaded for the external Hope bracket?  I’m not clear if you have all the parts separately or you have the frame with BB already and just want to fit the new crank
Posted : 06/09/2018 6:28 am
