Hi, wonder if any of you guys and gals ever had issues with your front mech not lowering enougth to allow the chain to ride without rubbing when on a 3 by 9 set up on a Cove Hustler?
Its a 2007 frame I just got from ebay I am trying to get up for my son.
Thanks
Roy
I suspect the issue is bottom bracket spacers I run two of the thicker ones on the drive side, I then have no problems :0) I am running shimano LX hollowtech 2
Mine has always had that, it only rubs slightly when on the stand, so no rub once on the bike with normal 12mm sag.
Running sram fwiw
ok guys been told by LBS fixed by fitting 42 tooth big ring - phew - will collect tomorrow and try out sunday on Milton of Balgonie Reliability run, good timing 😀
