Looking at a handjob frame with the cable routing on the top tube and no brake bosses. How can i tell what year it it as i want to run 120mm forks?
seller just says it is pre 07
I believe pre 2006 only good for 100mm
cheers
will
mine's 2007/2008. 15.5 ". Black. £170 posted...
cable routing is on the top yours is under top tube, so is the one im looking at earlier still??
Teeto, isn't yours a 2007? Looks like it. Good for up to 130mm if so, but best at a bit less imho.
Earlier one did have cable routing on top and 100mm max fork iirc
stanley - Member
Hmm, I bought mine in 2006... so accually, you could be right.. 😳
Yes, I have the 2006 and it IS the newer geometry (and 120mm is spot-on, I have a Reba maxle on mine).
Mine also has under top-tube cabling, so sounds like you might want to give that one a miss.
