Could I convert the...
[Closed] Could I convert these to LED?
3 Users
I have a set of Fireball all-terrain lights which I really like and are pretty good.
Like these
However, I have seen quite a few fantastic performing lights on here and I wondered if I could convert these to LED technology? I have a battery pack, charger, light housings and mounts so would it be easy to convert them? And roughly how much would it cost? Also, what's involved?
Thanks
Posted : 13/10/2010 9:16 am
Are the light units metal or plastic? You need a heatsink for the leds and a metal case will usually do
Whats the voltage on your battery pack?
[url= http://www.cutter.com.au/proddetail.php?prod=cut757 ]this kit from cutter will probably do the trick[/url]
Posted : 13/10/2010 9:20 am
The units are metal, I don't have the lights to hand and can't remember the voltage? I think the lights are 30w and 10w?
Kit looks interesting but 89.95 each, I think I may just stick with what I have...
Posted : 13/10/2010 9:25 am
Cutter have other cheaper kits - was that the aus dollar price?
YOu can do it with only one driver but then less flexibility, You can use cheaper drivers again cutter have them - as do others. I like that driver tho - the bflex as it is very adjustable and also has overheat protection
Posted : 13/10/2010 9:30 am
dx have a load of replacement options. Some work from a range of voltages so you might be able to re-use the battery and charger
[url= http://www.dealextreme.com/search.dx/search.cree%20module ]http://www.dealextreme.com/search.dx/search.cree%20module[/url]
Posted : 13/10/2010 9:36 am
