Cotic X (or Roadrat...
[Closed] Cotic X (or Roadrat) Wheelset options - hub alignment.
4 Users
I'm after another set of disc ready wheels for my Cotic X (for use with BB7s discs). I plan to keep the current standard Cotic Components/Alex rims as normal road wheels, and get another set with Open pro rims/CX tyres, so I can swap between them with out any alignment issues.
Are hubs the same spacing on disc and cassette position? or will I need to get another set of cotic hubs to make sure they swap over without requiring indexing/caliper position adjustments.
Cheers.
Posted : 25/11/2011 10:05 pm
Dunno if it helps but my bog standard Shimano hubs went straight in to the rear of my X and its fine.What I do find is that different discs do sit differently in the calipers so maybe stick to the same make discs
Posted : 25/11/2011 10:15 pm
How about these [url= http://singletrackmag.com/forum/topic/fs-mavic-a317-29er-wheels-on-deore-disc-hubs-700c ]shameless plug STW ad[/url]
£100 posted :mrgreen:
Posted : 25/11/2011 10:29 pm
I'll have a go fitting some old MTB wheels without tyres on to see how the discs align.
Tomaso, sorry not what I'm after.
Posted : 26/11/2011 11:22 am
They'll be very close and then you can space the rotors if needed using [url= http://www.jejamescycles.co.uk/hope-6-bolt-item8941.html ]these[/url] or similar. Works for me.
You may find the BB7's a pain to stop singing on the rotor anyway.
Posted : 26/11/2011 11:26 am
Cheers boxelder,
Do you have any issues with the rear gear indexing when swapping wheels?
Posted : 26/11/2011 11:30 am
No, but if there is it will be very slightly, so a small turn of a barrel adjuster and you're away.
May be worth making sure the rotors are exactly the same size/model, so that the pads wear matches both.
Posted : 26/11/2011 11:32 am
