Cotic x can I
[Closed] Cotic x can I
4 Users
run a flat bar?
MTB hubs?
160mm rear rotor and 180mm front?
Put a rear rack on?
Year of frame unknown but is bright green with steel forks, at 6ft but shrinking 58cm seems about right?
Posted : 15/07/2014 10:02 pm
Yes, yes, yes, not sure and yes
6foot and ran a 56cm with a 90mm stem
Posted : 15/07/2014 10:26 pm
 Pyro
Flat bar - probably.
MTB hubs - yes
160/180 discs - might be optimistic. 160, yes, as far as I know. 180, not sure the fork was designed for them that big. I'm running 140s front and rear on my (carbon forked) X and it's more than enough for me.
Rack - sort of depends on the generation of the frame. The last iteration (v3) had rack eyelets. Not sure earlier ones did.
Size - I'm 5'9" and comfortably ride a 54. You'll probably be right on a 58.
Posted : 15/07/2014 10:28 pm
My 1st gen will only fit 140 rotor at the rear
Posted : 16/07/2014 4:49 am
