Just ordered my Rocket frame.. no fanboi reason or anything just fitted the bill nicely and its pretty.
Can anyone explain to me how the combined rear pivot/brake mount works?
in this image it shows a small nut holding the seat stay pivot together, is this removed and a brake adapter put in its place to hold it all together? does that adapater fit flush to the frame? or are there spacers between frame and brake adpater?
thanks.
You just need a normal IS disc brake mount. It bolts into the hole just behind the nut you talk about and another that's just obscured by the axle.
Is that what you mean?
To me, it looks like the nut is only there to hold everything in place and should be removed when the adaptor is fitted.
thats what I was thinking dave... so the adapter fits flush to the frame...?
dave is right. I've got one.
excellent... thanks.
Yup, the bolt gets tossed. Otherwise it would foul the rotor...
I'd like to tell you more but unfortunately the day I built it I was suffering a two bottle red hangover and had to pass that task on to someone less fragile...
cheers fella, I will be building it myself, over a fair period of time so have every opportunity to get it right... going to send it to a LBS to have the headset cups fitted. The rest should be plain sailing.
Get them to clean out the threads on the bottom bracket too. This was also a task I passed on as feeling too fragile, I was scared I was going to strip the threads being hamfisted... There was definitely paint residue.
Why not get Cotic to fit the headset (either hope or nukeproof)?
School boy error... I have the top cup brand new unused from another project so thought I'd save myself a few quid. Thinking otherwise now.
how do you clean threads out?
I didn't. I actually built in the shop (now sadly closed).
Got the grease monkey to do it for me. And an excellent job he did too!
Just get the shop to do it same time as the headset (has the b/b been faced?). You may not have the same problem but the cups were sticking on the way in and I didn't want to force them.
My Solaris was the same, shop ran a thread cutter through it just to clear any excess paint. Just as well as it was a bit tight on that one too!
Ah ok so it has to be chased with the appropriate tool... Just googled it. Will get them to chase, face and fit headset then... The rest should be within my know how.
I have to highjack the thread and ask people not to post pictures of their rockets.
It makes me go all wobbly ,it sure is pretty and I will end up buying a frame.
PTR: Yeah, that's what I thought
I'd recommend not drinking two bottles of wine the night before you start it though...
You need to think about cable routing, etc. nothing major, just think it through first. When I did mine it was the first one out of Cotic and there were no pictures other than official ones (and I had some of the demo bike). Worked out all right in the end!
Have fun 😀
is there any literature that comes with the frame with ideas on best cable routing etc...? or is that just silly of me?
There should be an owners manual but it doesn't give any help re. cable routing. I have a PDF copy if you want?
The gear cable route under the shock (I've zip tied mine just to keep them neat). You should be able to get the jist of things for the rest of the photos on my Flickr site. Or indeed others. Try searching for cotic... If not I could take some more (specific) photos if necessary.
Ooh yes please, email in profile 🙂 be good to know what I'm going to stumble across before hand, so I can order any bits I need.
PTR - YGM mh
Thanks had to laugh at the headset section... More than a little misleading. It says it takes a zero stack 44mm cup and the below in the headset you need section it quotes you need a ec34 top cup.
PTR, you must be reading the 'tapered' headet section which applies to the new Soul only. You need to be reading the '44mm' section which applies to the Rocket. Zero stack 44mm top cup required:
http://www.cotic.co.uk/geek/44mm
Yeah but it's the rocket manual in PDF format... Surely it should only contain info on the bike it's for? I know what headset I need... Thanks
