I have a lovely purple 26” Cotic bFe frame that I’m building up and am fitting a rear 180mm rotor and cannot find anywhere to tell me what type of mount I need for the rear brake ?
Can any of the stw massif assist ?
(Apologies if this should be obvious - I have googled it and looked at the Cotic website to see if it’s stated there - but no, unless I missed it)
I have two Bfes, a 26 and a 650b, both run 180 discs, you will need an IS mount. Make sure you state 180 when you order.
Thanks volksman - will order 180 post to IS mount.
Not wishing to state the obvious but make sure you order a 180 rear mount, they're different front and back.
Thanks - I was super careful - two mounts, 180 front and rear. Double and triple checked IIRC.
