Corrosion in an all...
[Closed] Corrosion in an alloy frame??
6 Users
I've been thinking about getting a bit more serious about selling my Kona Jake the Snake, but when I went to start cleaning it up the other day, I noticed what appears to be rusty marks around the bottle-bosses. Pic here:
The frame is a 2007, so unless I'm (very) mistaken, supposedly completely aluminium. Could it just be the threaded inserts for the bottle-bosses, or the screwy-things themselves.
Any thoughts on this? Anything to be concerned about? Any tips on removing it?
Posted : 07/10/2013 3:47 pm
picky no worky 😳
Posted : 07/10/2013 3:48 pm
Now?
Posted : 07/10/2013 3:50 pm
that's better 😀
They could be rivnuts, which will be steel into the alloy tube
Posted : 07/10/2013 3:54 pm
 lerk
Hard to see, but looks like it could be galvanic corrosion at the junction between rivnut and frame... 🙁
Posted : 07/10/2013 5:28 pm
 kcal
I've got what I'd guess are similar alloy blisters, also around the bottle bosses (among other places) on my Stumpie M2 frame. It's 1998, so I guess yes there must be some kind of alloy corrosion / acute oxidisation happening.
Hasn't broken yet 🙂
Posted : 07/10/2013 5:40 pm
Okay, looks like some googling required. Hopefully it's not serious.
Cheers all.
Posted : 08/10/2013 8:15 am
 core
It's bugger all, they'll be steel or at least a steel alloy threaded inserts. There may be some galvanic corrosion as you get that when dissimilar metals are present: http://en.wikipedia.org/wiki/Galvanic_corrosion
But, it's likely to be very localised. My advice - small wire brush, some wd40 or similar, clean it up and it may slow down the corrosion, and will definitely make it look better.
Posted : 08/10/2013 8:19 am
Wouldn't worry at all. I've had loads of aluminium bikes with worse corrosion then that and non have failed.
Posted : 08/10/2013 8:27 am
