Anyone else had a problem with their Cook Bros Highline dropper post sinking ?
I sit on mine and it sinks. I stand up and it rises.
Crank bros?
Ooops Crank Bros Highline
if it's only just started happening, then it's probably just your cable tension being too high. Otherwise check the alignment of the connector at the bottom of the post
Connector alignment is fine. I'll check the cable tension. Thanks
I thought my connector alignment was fine too, but it was off ever so slightly and actually works better when the arrows aren't quite lined up. Doesn't make sense to me, but if It isn't your cable tension then that's what I'd be checking
