converting XT 2x10 ...
[Closed] converting XT 2x10 crankset to 1x11 - different chain ring bolts needed?
2 Users
as per title, changing my XT 2x10 (M785)crankset to a 1x11 using a hope (or similar) narrow wide chain ring. do i need different length chain ring bolts or can i just use the bolts from the 'big' ring on there at the moment?
Posted : 15/05/2016 7:06 pm
if the bolts are only holding one one ring, unlike a triple, then the same bolts should be fine. Some of the smaller rings are threaded so you don't need to use the nut part.
Posted : 15/05/2016 7:13 pm
thanks
Posted : 15/05/2016 7:30 pm
