Converting with a b...
[Closed] Converting with a bash ring
10 Users
I presume I'm correct, I want to put a bash ring on notepad of 3rd cog. I never use the top cog, is it jus a matter of buying a bash ring and sticking it on?
Posted : 21/04/2013 6:36 pm
yeah pretty much - make sure the bcd is correct
do you hit lots of stuff with your chainrings currently ? If not, just stop using the big ring and leave it there
Posted : 21/04/2013 6:39 pm
Yep. However, you may need some longer chainring bolts, especially if you get a plastic one. Good news is some come with the chainring bolts. I got a plastic blackspire c4 last year and I've given it some good bashes into rocks and logs and it's still going strong.
Posted : 21/04/2013 6:41 pm
Yeh Iv been hitting it a few times. What is BCD?
I have a raceface crank does that make my difference to the BCD?
Posted : 21/04/2013 6:42 pm
BCD (Bolt circle Diameter) is the distance between the bolts, Measure from the centre of one whole to the centre of the next one round the circle. I would expect it to be 110mm as this is fairly standard now but worth checking.
Posted : 21/04/2013 6:45 pm
Good idea to fit a bashring IMHO, just Google chain ring injury on Google images to see why... 😕
Posted : 21/04/2013 6:57 pm
I just checked the measurement from one hole to the other and dent get what I expected, so I presume I measured it wrong. On my 3rd cog it has written on the top 104 is this the size I would need?
Posted : 21/04/2013 7:02 pm
yes and it is the standard size
Posted : 21/04/2013 7:06 pm
Yes, sorry my bad, 110 is the BCD for most touring cranks and 104 for mtb, so you are bang on. As stated above if you choose a thick plastic bash then you will require longer bolts as well.
Great thanks, now il try and find one
That's not BCD. For a four-arm crank (assuming it's symmetrical...) it's the distance between the centres of the two [i]opposite[/i] bolts.
Posted : 21/04/2013 7:12 pm
Ive got a standard SLX bash ring, with bolts and 104 BCD you can have for 8 quid posted? see it here - [url= http://singletrackmag.com/forum/topic/wee-clearout-hope-e13-etc ]bash[/url]
Posted : 21/04/2013 7:46 pm
Perfect, il take that off you
Posted : 21/04/2013 8:10 pm
Don't mean to get in the way of you guys trade, but thought I should warn you the SLX M665 bash doesn't fit on a standard three ring crankset without a bit of filing - about 1mm or so off the bash at each of the spiders. It's not a question of BCD which is the same, but that Shimano made the spider a bit shorter on the M665 so the bash could be thicker and stronger round the crank arm bolts. You'd be better off with the E13 which will fit a standard spider without any modification.
Posted : 22/04/2013 3:55 am
its really easy done it last week!
went from 3x10 to 2x10 with a bash.
at the same time i put new chainrings on with different teeth so now am running 22/36 instead of 26/34/44, helps with getting up the hills.
Posted : 22/04/2013 5:41 am
