Converting to 1 x10
[Closed] Converting to 1 x10
6 Users
On my Hardtail (Cannondale).
Currently Running 3x8 mixture of Acera and Altus bits and I'm sick of my front mech needing a constant clean if the going gets muddy. Will I notice any good and bad points getting rid of the three rings up front for one. I only use my Granny ring at the moment as physio have said spin in A easy gear after knee surgery, but by spring and back to normal I only use the middle ring.
What do I need to change to 1x10 and I'm hoping to upgrade to SLX or XT
Posted : 20/01/2014 9:44 am
Chainguide or appropriate chainring/mech.
Posted : 20/01/2014 9:47 am
- chainring (ideally thick thin), narrow chainring bolts (unless you use a bash ring)
- 10 speed shifter, 10 speed mech (Zee FR seems to be the best value IMO), 10 speed cassette, 10 speed chain
With that setup you shouldn't need a chain device.
I'm also assuming that your chainset is a standard 4 bolt design.
I've gone to a thick/thin chainring on my 1x9 bikes with no clutch mech or chain guide and have had no problems.
I'd get the ring and see how you get on.
tbh, though, if I'd had knee surgery I'd be keeping the option of a lower gear for climbing for days when I wasn't feeling on top form. Maybe look at a 2x10 setup?
Posted : 20/01/2014 9:50 am
Wwaswas- yeah you maybe right. I have just finished a short ride, I'm four weeks post op and managed 4 miles and my knee's ballooned.
I did originally think 2x10 with bash. May look into that.
Posted : 20/01/2014 10:04 am
Get the setup I described above as a double and only change to 1x10 when you're recovered.
Posted : 20/01/2014 10:07 am
Which rings? Any links. And do I just bolt my current cranks onto the rings. They are the four bolt design.
Posted : 20/01/2014 10:42 am
Some people have removed all the front mech and shifter parts but left the chainring
no problems with mud, you get the weight loss and if you need to you can shift the chain onto the small chinring and back manualy.
Posted : 20/01/2014 10:47 am
You could just stick with your middle and granny rings for now with the 10 speed rear set up and when your knee is better, remove the granny and replace the middle with a thick thin (and take off the front mech/shifter of course).
Or just stick with 3x8 until your knee is better and change to 1x10 then.
Posted : 20/01/2014 10:49 am
Yeah gonna be about April time I change. Current progress isn't going as well as I'd hoped. Walking upstairs is better but I can't stand on pedals for more than two minutes at the moment.
When I do change I take it a four bolt ring will work with the cranks I get?
Posted : 20/01/2014 11:02 am
Yes, it should just work in middle ring position.
Posted : 20/01/2014 11:56 am
I would stick with the 3x8 for a bit.
Your triple cranks should be fine if they are are 4 arm but you will need to replace the crank bolts to shorter ones when you switch to 1 x 10.
When you do switch I would look at something like this.
XT/SLX clutch mech £40-50
XT 10 SPD cassette 11-36 £37
Zee Shifter £24
KMC X10-93 10 Speed Chain £20
Works Components Narrow Wide Ring £35
Posted : 20/01/2014 12:15 pm
