Converting Thru Axe...
[Closed] Converting Thru Axel Rear to Boost
3 Users
I have a standard thru axel rear wheel on my Codeine 29r. Thinking of swapping the frame for a Solaris Max, but it has boost spacing. What do i need to convert it? And do i need to change the rear mech??
Posted : 27/07/2018 9:01 am
Mech will be the same. By standard thru axle I'm assuming you mean 142x12. You will need some spacers (eBay). There are two ways to do it. Firsts is a 3mm spacer on either end of the axle and 3mm spacer on the disc mount. This requires no change to the wheel but will have a sub optimal chain line (as the cassette will be 3mm further inboard than normal). The second way is one 6mm spacer on the disc side, a 6mm spacer behind the disc (don't forget longer disc bolts!) and a slight re-dish on the wheel to centre the rim. This way puts the cassette in the correct position.
Both ways assume 6 bolt rotors. If your centre lock then new wheel time.
Posted : 27/07/2018 9:27 am
Cheers nixie. Nice and clear answer. ta
Posted : 27/07/2018 9:32 am
There are now centerlook boost adapters.
3mm spacers each side does not always work with some frame/mech combinations.
Posted : 27/07/2018 10:23 am
