converting SS to ge...
[Closed] converting SS to geared
4 Users
Got a Kona unit with a formula hub
The freehib looks too small to take a cassette
Can I just stick on a new freehub.....
http://www.edinburghbicycle.com/products/formula-freehub-body-8-speed-w-socket-tool
Says 8 speed only ? I thought 8 /9/10 speed fit on the same freehub
Also if anyone has a geared dropout going spare for a new explosif/ unit I'm interested !
Posted : 13/08/2014 9:00 pm
Fit and 8 speed Alfine and be done. Mine can be swapped in minutes - although I ride exclusively SS.
Posted : 13/08/2014 9:39 pm
Can't afford a new wheel at the moment !
Posted : 14/08/2014 8:43 am
The freehub won't fit, even if by some chance it would bolt on it would be too wide.
I'd look for a second hand wheel if I was looking at gearing up my unit.
Posted : 14/08/2014 8:40 pm
 Andy
Sounds like you have a Singlespeed cassette hub which is basically a narrow free hub. You might be able to fit more than one sprocket on and bodge a 3,4 or 5 speed set up depending on how wide it is. Alternately you need a new hub or wheel if you want to fit a full cassette as your current hub will be wrong to take a 9/10 sp cassette.
NB if you can fit 2, 3 or 4 sprockets on your hub why not do a 1x 3 set up 😀
Posted : 14/08/2014 8:59 pm
I think I had the same hub, it won't take any more than 1 sprocket I don't think. The lockring takes up too much room.
Posted : 14/08/2014 9:07 pm
