A quick you tube search was fruitless.
I've got a superstar 10mm we and 2 new hope end caps.
Do I need anything else and how do I do it?
Which hope hub?
Should just be a case of remove old end caps, fit new ones. Fit 10mm skewer, put wheel in frame.
Just pull of the q/r end caps and push on the 10mm caps.
^^This.^^Just pull of the q/r end caps and push on the 10mm caps.
Did it to my Pro3 SP rear a few months ago and couldn't believe how easy it was. Only took a couple of minutes.
You only need end caps if it's a Pro3 or Pro2 Evo.
If you have an older Pro2 you need the kit with end caps and a new axle.
Job done less than 2 minutes.
Thanks y'all.
Is converting to 12x142 just end caps too for pro2 evo?
Yes you need the X12 end caps
