Converting from dro...
[Closed] Converting from drops to flat bars .
9 Users
Got a Giant Revolt CX bike , I've got the original stem that's a bit longer , a spare pair of bars and a pair of shifters knocking about . Just had a shufty on tinternet seems a pair of levers for the Avid BB7s are cheap as so have I missed anything and more importantly will I regret it ? I spend most of the time on the hoods rarely if at all on the drops . Will the reach be too cramped ?
Posted : 11/12/2017 10:13 pm
I've always found it to be fine!
Posted : 11/12/2017 11:24 pm
My mate did exactly this on his genesis day one, worked fine.
Posted : 12/12/2017 12:49 am
Biggest benefit is cheap hydro brakes, so shelve the BB7s and get any Shimano. BR-M355 upwards.
Posted : 12/12/2017 4:58 pm
if you run road mechs you'll need flat-bar shifters (440, 770, 780) and not MTB shifters.
Go hydro on the brake too. Much better.
Run the stem a bit longer, as you say.
Fit bar ends for better positions/climbing. Ergon-type grips good too.
Posted : 12/12/2017 6:19 pm
Shimano 10 speed road/MTB are not compatible. I bought a new rear mech once I had worked this out.
Posted : 12/12/2017 7:07 pm
Slight hijack. I've got a Spesh Allez road bike & really can't be doing with drops, what kind of ballpark figure would put flat bars on it, in total?
Posted : 12/12/2017 7:15 pm
If it's got half decent kit on it then you might break even, as roadie shifters can fetch a bit second hand.
I'd say about 50% of people who currently ride drop bars would actually be better off on flat bars. They're certainly a fashion. I'd say go for it.
Posted : 12/12/2017 8:13 pm
Thanks for the heads up about shifters , that's stopped my gallop !
Posted : 12/12/2017 9:25 pm
I switch between drops, risers and bullhorns all the time (easy for me as I have no gears or brake levers to worry about)
I use the same stem with all bars. I mostly prefer the risers as I ride off road and they make the bike more fun to manoeuvre around, jump over things etc,. but the single hand position is not so good for longer riders and I miss the multiple positions of the drops (or even the bullhorns)
Your hands are also at a more natural angle on hoods but if you are on hoods pretty much 100% of time you won't miss much.
Posted : 13/12/2017 6:43 am
