Converting DT350 fr...
[Closed] Converting DT350 from 20 to 15mm?
6 Users
Looking to convert a DT350 Oversize front hub from 20mm to 15mm. Is this the correct part #? HWGXXX00S4470S
If so, any ideas of somewhere that would have stock or would I need to order through Madison?
Posted : 03/03/2016 8:26 am
Anyone?
Posted : 03/03/2016 11:07 am
 gary
The DT site says "no solution". I think its because the 20mm 350 hubshell is full width - ie. 110mm - so you can't shorten it by changing end caps.
"Please note, these hubs are not interchangeable between different axle types; all three hub shells are different"
[url= http://www.justridingalong.com/wheel-parts/hubs/dt-swiss-350-6-bolt-front-hubs.html ]http://www.justridingalong.com/wheel-parts/hubs/dt-swiss-350-6-bolt-front-hubs.html[/url]
Posted : 03/03/2016 11:12 am
Just found the tech doc: https://www.dtswiss.com/Resources/Support/HUBS/DT-Swiss-Hubs-350-Technical-Manual
Page 13 shows the 350 OS hub. Looks like it comes apart easy enough so I'll have a look and see if I can make something. There are end caps on there (and a sleeve) so I would have thought shorter end caps and a 15mm sleeve would work?
Posted : 03/03/2016 11:18 am
Contact Madison via their on-line enquiry page. They'll tell you if there's a part available and where to get it if so. They responded very quickly to a 350 hub query I had a few months ago.
 gary
I knew I'd read the thing about width somewhere. Of course CRC answer could be wrong ...
"No, sorry; the 350 hub runs a pre-built 110mm width for 20mm thru-axle and cannot be converted down to 100mm as required for 15mm/QR. The 15mm version of their hub can be converted down to run QR, but the 20mm version is not convertible."
[url= http://answers.chainreactioncycles.com/answers/5230-en_gb/product/prod38128/dt-swiss-dt-swiss-conversion-kit-20mm-to-qr-front-questions-answers/questions.htm?sort=recentq ]http://answers.chainreactioncycles.com/answers/5230-en_gb/product/prod38128/dt-swiss-dt-swiss-conversion-kit-20mm-to-qr-front-questions-answers/questions.htm?sort=recentq[/url]
Posted : 03/03/2016 11:27 am
I don't think you can convert like you can with Hope hubs. I would like to be able to do this too to use a winter tyre on another bike but don't think it is possible.
Posted : 03/03/2016 11:44 am
All the other DT hubs I've come across have been easily convertible, looks like it's just the oversized 350's that aren't.
Posted : 03/03/2016 11:48 am
I, stupidly, presumed that by buying the biggest hub it would be convertible to all normal sizes (15/9mm etc) but that doesn't appear to be the case. Nice one DT 👿
Looking at the schematic it can't be that hard to make something on my CNC's that will replace the normal end caps and spacer to suit 15mm?
Posted : 03/03/2016 11:59 am
The flanges on the OS 350 are 11.9mm (110 - 23.3 - 32.2 vs. 100 - 22.4 - 35) farther apart, I assume this will cause some clearance issues?
Posted : 03/03/2016 12:19 pm
