Just because my google fu is weak today (like the rest of me then.....) can I convert my Chris King 15mm front hub to 20mm and where can I get the parts to do it?
Cheers guys.
th ld hub you can convert to 20mm with a new axle kit. the sd ( small dia) hub, no can do. Only 15mm axle fits the sd hub
I'm in luck then, as it's the ld I have.
Now to track down a 20mm conversion kit.....
got mine from leisure lakes
Think I got my last one from aspirevelotech
I've just bought a used one on ebay - must be my lucky day for a change!
Thanks, Andy.
Andy R...is your LD first gen (serial 171...) or 2nd gen (serial 172...) If is the 171 then do you feel like selling me your 15mm axle? 🙂
It's the first generation but I think I'll probably keep the 15mm axle, just in case I want to go back to using Fox or something rather than Marzocchi.
