Converting 100mm re...
[Closed] Converting 100mm rebas to 120mm
5 Users
Anyone got any guides on how to do this it would be much appreciated.
I have been searching and can't find any guides.
My forks are 2009 Reba SL's are these compatible to do this?
Thanks Pete
Posted : 18/05/2011 3:06 pm
+1 thinking of doing this myself!
Posted : 18/05/2011 3:11 pm
This is for older Rebas, so you might find slight differences and the spacers might be at the bottom of the rod, but the technique is the same
https://docs.google.com/viewer?a=v&pid=explorer&chrome=true&srcid=0B1AoGIWBz4H1M2E5ZTc0MTItNjM4NS00YjBiLWEwZDgtMjEyYTQ5NWZlMjc5&hl=en
Posted : 18/05/2011 3:12 pm
Are all Reba models convertible? I had the older SL and apparently it could not be converted to 115mm from 100mm.
I now have the Team model and took the spacer out to increase the travel. Quick 20-30min job and You can clean the seals and change oil in lowers while You're at it.
There is a vid on Youtube by SRAM. Check out how to service dual-air air spring and it will show You how to do it step by step (I find vids easier to follow then guides with photos), basically it's like a service but You just don't put the spacer back. 🙂
Posted : 18/05/2011 3:19 pm
There was a good step by step guide on (shudder) bikeradar that I used to alter a pair of 2009 SLs to 120mm.
Posted : 18/05/2011 3:24 pm
No, but THE only way to be sure is to open them up.
Model number/name is no indication at all.
Every RS fork I've had apart (Must be a dozen or more by now) could be extended.
That's awesome guys THANKS A LOT 😀
Posted : 18/05/2011 3:38 pm
