Does anyone know how to convert someone's route that is on Strava to GPX ?
I'm using Viewranger which is set up for GPX files and I would like to follow someone's routes from Strava.
You need to be a Strava premium member to download other peoples routes.
Or
http://www.mbtom.co.uk/how-to-download-strava-gpx/
Yep, that works. Cheers 🙂
Does it work for whole routes as well as segments? The instructions just refer to segments.
Ta.
Works for routes with me, it's what I use strava for in the main .
Without being Premium, their Activity as one of your Routes. Then download your Route as GPX
As @jamiep says: Select the route then click the spanner icon on the left then chose "Create Route".
When you do this Strava announces to the world that you have done so: "grannyjone has created the route fubar" but this new route is one of your routes so you can download it.
Tick
Thanks, these have worked. It is still a fiddly operation but it works. First I use the first website to convert the strava route into a CRS file. Then I use the second website to convert the CRS into a GPX. Fiddly but it works.
