Convert 150mm Pikes...
[Closed] Convert 150mm Pikes to 160mm?
8 Users
Is it possible a all? and if so, is it costly or difficult to do?
Posted : 04/10/2014 6:48 pm
Just needs a new air spring shaft, I think- Loco'll be able to sort you with the part if so
Posted : 04/10/2014 6:51 pm
Not possible as far as I'm aware you can space down but not up but with new internals you will be able to.
Posted : 04/10/2014 6:52 pm
£35 RRP for a new air shaft, less if you shop around
Posted : 04/10/2014 7:03 pm
Booyakka
http://www.amazon.co.uk/gp/aw/d/B00G239WX0?pc_redir=1407723883&robot_redir=1
Double check its what you need obviously
Posted : 04/10/2014 7:09 pm
Sounds good, so stanchions etc are all the same?
Anyone here have 150mm pikes? Do they have 2 sets of sag measurements? ie. the measurements for 150 and also 160?
Posted : 04/10/2014 7:38 pm
Yep.
160 51 offset 29er Pikes were unavailable in the UK so i bought 150 51 offsets and put a 160 airspring in them.
Sorted.
Posted : 04/10/2014 7:49 pm
Excellent.
Thinking of doing a Joe Barnes on one of those Spectrals and turning the fork (Pike 150 comes with it) into a 160 for an enduro weapon.
(not that I ride anything like JB!)
Posted : 04/10/2014 7:55 pm
 SOAP
Tf said No.
Posted : 04/10/2014 7:58 pm
"Tf said No."
-- As in can't be done?
Posted : 04/10/2014 10:11 pm
I've done it to a couple of 150mm 27.5" Pikes. Works a treat.
Posted : 04/10/2014 10:51 pm
