Conti tyres - OEM? ...
[Closed] Conti tyres - OEM? Have I been had?
14 Users
Just replaced a Conti GP 4 seasons with what I thought was an identical tyre from a well known online retailer. However, the sidewall has red painted on cross hatching rather than a sort of rubberised 'checkerboard' finish, and the tread doesn't feel the same as the one which I had originally.
They assure me it is identical, but it doesn't feel the same and it doesn't look the same. So how can it be the same? I don't get it.
Does anybody know, are they ****ing me over or have Conti just changed the design at some point?
Posted : 15/09/2015 3:13 pm
I have no idea about these tyres or road tyres in general but a quick image search on google threw up several of the tyre with red hatching on the sidewalls....
Posted : 15/09/2015 3:34 pm
The legit aftermarket 4 seasons should have 'Made in Germany' on the side of them.
If they have that you're good.
Posted : 15/09/2015 3:42 pm
i would be tempted to phone the importer/ distro. they should give you definative advice, and advice which the shop should heed.
which i think is madison
Posted : 15/09/2015 3:56 pm
there is more than one importer. i.e Cambrian.
Posted : 15/09/2015 4:02 pm
The ones I've always had have always had red 'threads' showing on the sidewall. Wouldn't say it it looks painted on though.
Posted : 15/09/2015 4:12 pm
I seriously doubt you've 'been had'. Nothing wrong with using OEM, unless you like cardboard boxes to put in the bin!
Posted : 15/09/2015 8:05 pm
Okay thanks all. I'm not normally against OEM as long it's the same spec (or at least I know what is different before I buy). It was the fact that these feel and look different that threw me off. I thought they might be a worse spec of rubber like the non-black-chilli Conti mtb tyres you used to get cheaply online.
These both have the "Made in Germany" decal so I guess it's just a change of design at some point. Actually I can't even find a pic of the black sidewalled ones online, so maybe that is the one I should be questioning…
Anyway cheers everyone
Posted : 15/09/2015 8:39 pm
It's a good question IMO. Some OEM tyres fitted to new bikes are absolutely dreadful.
Posted : 15/09/2015 8:43 pm
Indeed. A bit like the difference between "normal" and Black Chilli versions. OEM tyres are often shittily made to a low budget to get a name on there. It's not just about the packaging....
Posted : 15/09/2015 8:44 pm
As per njee..."red thread". I'd say they're legit, unless the feel "way off". Pressure, greasy roads etc maybe got you overthinking the feel?
Posted : 15/09/2015 8:53 pm
I have just bought a pair of GP 4 seasons online and they came without packing but with a plastic strap around them. They seem to have all the correct markings. I did question the supplier as to whether they were OEM (which could have been had from an alternative dealer for £7 a tyre less)and was told they were aftermarket but bought in bulk from Conti. and were supplied like that I haven't ridden on them yet so can't comment on feel. Incidentally I also bought some Conti tubes from another dealer and they had all the packaging. Not sure now.
Posted : 16/09/2015 8:08 am
You can spec German made BC Conti tyres as OE.
Posted : 16/09/2015 10:45 am
Is it [url= http://www.continental-tires.com/bicycle/technology/city-trekking/duraskin ]the Duraskin sidewall protection?[/url]
Posted : 16/09/2015 12:59 pm
I'm with the OP on this - i'd like to know whether the tyre I was buying was OEM or not.
I used to work for a rubber manufacturer (Sava) who produced tyres for Good Year. Different factory, different compound but labelled up as the leading brand.
Posted : 16/09/2015 2:13 pm
