considering 1x10 sp...
[Closed] considering 1x10 speed.. what's best way to do it?
13 Users
I'm considering ditching the 3x9 on my bike and going either 1x10 or 2 x10.
What's the best way to go?
Riding the chilterns so nothing to demanding.
Is there a decent chain guide that doesn't cost the earth?
Likewise for the bash guard and single front ring!!
Steve
Posted : 06/03/2013 1:54 pm
MRP AMG looks decent, and is cheap on EBay - top guide & bash combined
Posted : 06/03/2013 2:14 pm
Just by a 10speed downhill specific chainring and don't bother with a chain guide, for the easiest way. Something like the KCNC ones or the Gusetts.
Posted : 06/03/2013 2:18 pm
I have the AMG guide coupled with an MRP bling ring and SRAM type 2 rear mech on 1x 10. Perfect set up so far. Bling ring is quite hard to get though and you need certain trivia tic/SRAM cranks to run one.
Posted : 06/03/2013 2:25 pm
Thanks for the replies.
Ideally I want to keep my xt cranks and just change the ring.
How much weight can you potentially save converting to one chainring and are there any issues with chain line etc?
Posted : 06/03/2013 2:27 pm
I use a really simple set-up and didn't cost much at all.
All I use is a 32t chainring with a bbg bash guard either side of that holds the chain in place, it's light and cost me about £20. Here is the link to the website
http://bbgbashguard.com/
Jim
Posted : 06/03/2013 2:28 pm
You are replacing the middle ring which is OK in all cogs at the back so there should be no chainline problems.
Shorten the chain as much as possible.
Ideally get a new clutched derailler.
Fit it a chain guide system.
I've been using a top-only guide on my 1x9 HT for the last year which works most of the time bit I still jam the chain in the device sometimes when the going is really fast and rough and the chain still slaps about noisly and pops off the bottom of the chainring all the time, as it does with the double/triple system.
I'm thinking about a top-bottom guide for the future for silent running.
You'll get a worthwhile weight reduction, but the real benefit is simplicity of use IMO.
Posted : 06/03/2013 2:35 pm
The Swedish Chef - Member
Apart from your chain falling off, that's perfect
Posted : 06/03/2013 2:37 pm
Any chain ring recommendations to have a look at?
Posted : 06/03/2013 3:16 pm
Race face single ring, rental rings both strong but light weight
Posted : 06/03/2013 3:30 pm
jim33 - possible numpty question, when using the inner ring mounted bash does the 32T version cover a 32T ring in the middle position? If you see what I mean!
Posted : 06/03/2013 3:50 pm
My 1x10 set up on my Soul:
Mrp podium ring
Mrp 1x top guide
Xt shadow plus
Saint dual release shifter
Xtr m970 cranks 32:11-36
Gives me a silent chain slap free drivetrains!
Posted : 06/03/2013 4:03 pm
 br
[i]Riding the chilterns so nothing to demanding.[/i]
But in another post you suggested that you were unfit to ride with others in the Chilterns...
You are going to save bu99er all weight going 1x10, and will also then have to avoid steep climbs, or walk.. - such as out of Wormsley Park towards Ibstone or Northend.
Posted : 06/03/2013 5:29 pm
Single speed rear hub with 13t cog, rear mech to take up slack then a 13-42 ten speed chainset.
Posted : 06/03/2013 5:33 pm
Br good excuse to get fit then!!!
Posted : 06/03/2013 6:19 pm
I've goit a blue Superstar seat tube mount one you can have for a tenner
Posted : 06/03/2013 6:34 pm
clutch rear mech.
hope integrated chainring / guide / retainer.
job done !
Posted : 06/03/2013 6:47 pm
 br
[i]Br good excuse to get fit then!!! [/i]
Wrong way. Get fit and then prove it to yourself by going out and not using the granny. Only then is it worth 1x10.
There are any number of climbs (as in short, sharp, shocks) that only a serious fit rider will get up in the Chilterns using a 1x10.
Posted : 06/03/2013 7:14 pm
Why not try the 1 x 10 option with a smaller chainring if you're worried about 32/34 being too difficult renton? 28t or 30t available from MRP for SRAM cranks and maybe others offering 30t for Shimano.
Posted : 06/03/2013 7:25 pm
honourablegeorge - Member
Actually not with a Type2/clutch rear mech and the new XX1 style teeth on the KCNC rings.
Posted : 06/03/2013 7:27 pm
What's the script with the KCNC rings? Can't find anything online, other than that they claim their old DH ring will work fine without a guide- unlike every other DH ring.
the_lecht_rocks - Member
job done !
They're really pretty, but it's a bloody expensive way of going about it, not to mention turning the bashring into a consumable (and high cost of changing ratios)
Chainring of your choice + MRP 1X guide + clutch mech- lighter, cheaper, just as effective, lower ongoing costs.
Posted : 06/03/2013 7:30 pm
The thing is I dont remember the last time i used the outer ring and I have very rarely used the granny ?
Posted : 06/03/2013 7:42 pm
See Clee Cycles description, (no connection)
http://clee-cycles.co.uk/esite/P11102/product
Posted : 06/03/2013 7:53 pm
That's all i could find- but there's nothing special there, it's just a deep-cut chainring. Have you used one?
Posted : 06/03/2013 8:01 pm
I've got a 32, and am waiting for the 34 and 36 tooth so I can select the correct one for each race.
Posted : 06/03/2013 8:18 pm
