Confused by bodies ...
[Closed] Confused by bodies - cassette bodies that is
4 Users
My freewheel stopped doing it's job properly so I whipped it out to see what was going on and that is where my confusion starts.  The part I took out is this:
https://s31.postimg.cc/phfu60rzf/IMG_20180415_164138574.jp g" alt="" width="600" height="800" />
It came off a road wheel with a shimano 10sp cassette on it.  The last time I replaced one of these it was the older bolt on shimano freehub body and another set of wheels I have has a DT hub with splines to receive a DT freehub rather than the pawls of a Shimano hub.  This is the first time I've had to replace one of these
So, the big question is do I just buy any old 'cassette body for shimano 10speed' or are there differences to be aware of?  If I look at Novatec parts for example there appear to be at least 3 freehubs that would match (A2,B1 and D) without any indication of what the difference are.  Can I buy any old 10spd freehub with pawls and are there any particularly good makes
Thanks all
Posted : 15/04/2018 4:04 pm
Almost entirely yes...if you have a steel cassette, don't get an alloy freehold as it'll get chewed and destroyed. If an alloy cassette then an allow frehub is fine.
Posted : 15/04/2018 4:08 pm
My freewheel stopped doing it’s job properly
There's your problem right there... nothing worse than cosmetic damage*
I whipped it out
Not in public I hope!
* to avoid confusion, this is not really true, although see below.
Posted : 15/04/2018 4:21 pm
In answer to your question.. get a noisy hub to scare off dangerous wildlife, and you will feel better for having a shiny new part.
Posted : 15/04/2018 4:23 pm
No, I don't think so.  The actual freehub body is often specific to the hub.  They often fit different size end caps/axle parts etc.
The splines themselves will obviously be standard to suit a Shimano cassette but the internal details can be quite different.
If you have identified the hub and the compatible freehubs, go with one of those.
But as per above, a little chewed up doesn't make any difference other than to make it a little harder getting cassettes on or off.  Unless it's really chewed up and the sprockets are loose even with the lock ring done up tight.
Posted : 15/04/2018 4:26 pm
It's a wheelsmith hub and if I go to their site it says 'Spare Freehub body for Wheelsmith hubs only' which I guess answers my question.  I was wondering if there was a 'standard' but I'm not sure there is as when I hunt I find specific bodies for Hope and Nukeproof so it doesn't look like there is.  Might just need to order from Wheelsmith which isn't a problem - was just interested in what the options were
edit: the problem wasn't that is was chewed up.  I've take a file to sort out the worst of that.  The problem was that it was no longer freewheeling properly
Posted : 15/04/2018 4:30 pm
