Compression tops - ...
[Closed] Compression tops - Skins alternative
6 Users
Hi Chaps,
I'm after a compression base layer / long sleeve top, I'd love to buy a Skins or a 2XU.. but they are expensive.
Has anyone bought a cheaper alternative that is actually just as good, or is the price fully justified for the tops?
I've got a Skins bib, which I can see the benefit of the cost for - as the padding an fit is very good indeed.
Ricks
Posted : 31/03/2011 9:28 am
 GW
just wear your girlfriends/sisters underwear
Posted : 31/03/2011 9:30 am
I was thinking a large area of compression... not just the nadgers.
Posted : 31/03/2011 9:33 am
http://www.maxgear.co.uk/CompressionClothing/index.html
Have used them for 6 mths and just as good as my skinz tops.
Try the discount code MAXRT10 for a 10% discount on checkout, not sure of it still works as it was sent to me last year.
Posted : 31/03/2011 9:51 am
Decathlon's own version is perfectly OK and, as ever, quite cheap. You can also occasionally pick up some of the UnderArmour stuff cheaply in JJB Sports.
Posted : 31/03/2011 10:17 am
 LoCo
Ricks, on the case 😀
Posted : 31/03/2011 10:21 am
im sure lidl are doing the compression base layers and aldi had them,never used them though....
Posted : 31/03/2011 4:35 pm
