Compatability Confu...
[Closed] Compatability Confusion!
3 Users
Hi all,
I'm waiting for a nukeproof rear hub conversion kit to arrive
http://www.tredz.co.uk/.Nuke-Proof-Conversion-Kit-QR-Rear_37343.htm
(I've been waiting 2 months now 🙄 )
It's to convert my NP Generator rear hub from 12mm to QR.
Am I right in thinking that most rear QRs are 10mm?
The conversion kit says it converts to 9mm QR though, which leaves me wandering whether the standard hope QR I've got will fit.
I wouldn't normally worry about such a small detail, but I really wanna build the bike on Saturday, so I need to get a new QR sorted quickly if it won't fit.
Thanks!
Posted : 12/03/2013 8:20 pm
Bump
Posted : 12/03/2013 8:32 pm
The part you have ordered there will convert your hub to a 9mm quick release skewer [url= ]like this[/url] not like your thinner hope skewer, if your frame wont accept the 12mm hub, there are various step down skewers you could have got instead that will fit in the 12mm axle but have thinner 10mm ends that would fit into your frame
Posted : 12/03/2013 8:40 pm
Great, thanks, looks like I'll need a new QR then 🙁
Posted : 12/03/2013 8:45 pm
My Orange Five frame is designed for a standard QR, does that mean this 9mm QR may not fit?
Posted : 12/03/2013 8:50 pm
edit.
i know what i mean but im struggling to explain it.
a standard QR will fit that axle adapter you have ordered.
Posted : 12/03/2013 8:55 pm
Okay, I think I may now be more confused then when I orginally asked the question.
It would make sense for a standard QR to fit, as I don't understand why NP would make a hub converter that only fits with really obscure skewers?
Also toppers standard QR's are not 9mm.
Maybe its the axle that's 9mm and a standard QR fits inside? That would make sense.
Posted : 12/03/2013 9:01 pm
It wont fit, a hope skewer is about 5mm, the part he has ordered is basiclly a tube with 12mm outside diameter and 9mm inside, I know because I have researched into doing the same thing a while back with my Nukeproof hub
Posted : 12/03/2013 9:02 pm
toppers could you try please? 🙂
Posted : 12/03/2013 9:03 pm
this.
on the front anyway. front axles are usually 9 or 9.5mm. rear are usually 9.5 or 10mm. the skewer is indeed roughly 5mm.
and that np axle is to convert a 12mm hub to take a standard 5mm skewer like shimano and hope.
the centre section is 12mm, the 2 narrower sections at each end are to fit a standard dropout and you can see the hole through the centre which will take a standard QR.
Posted : 12/03/2013 9:05 pm
Okay, thanks, that would make sense, but where does the 9mm come into it?
Posted : 12/03/2013 9:10 pm
Spuddle, did you actually buy one in the end?
it refers to the axle/dropout size, although that would actually be 10mm on the rear.
10mm qr's are exactly that, 10mm the hub fits flush to the inside of the drop out and the qr actually seats in the dropout rather than the hub axle. it is a compromise between a bolt through and a standard qr.
Posted : 12/03/2013 9:15 pm
Okay I think (hope) that I understand now.
I think the outer diameter is 12mm, then the diameter at the edges (where it steps down) is 9mm, and I'm assuming (hoping) it has a 5mm diameter hole through the middle for a standard QR.
The step down bit goes in the drop out and is 9mm wide.
That would make sense looking at the photo, and the standard QR just clamps this axle in place.
Posted : 12/03/2013 9:19 pm
bingo.
Posted : 12/03/2013 9:20 pm
Okay, I'll just wait for it to arrive, and cross my fingers in the meantime.
Posted : 12/03/2013 9:22 pm
all you really needed to buy was [url= http://www.protone-components.it/catalogo/product_info.php?products_id=265 ]this[/url] or [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=65450 ]this[/url] personally id not trust putting a 5mm skewer into a 9mm hole.
Posted : 12/03/2013 9:27 pm
Yes Spuddle, in hindsight that would have been a good idea, but I had no idea those step down axles existed 2 months ago when I ordered the kit.
I just hope the kit works as I think it should - if not 😈
Posted : 12/03/2013 9:30 pm
Also, I'm pretty sure it's a 5mm hole, I'll let you know after it has arrived.
Posted : 12/03/2013 9:31 pm
Or even if you wanted to, id have swapped my QR axle for your 12mm one!
Posted : 12/03/2013 9:32 pm
the np axle is exactly the same thing as the axle in spuddles second link, just made by np not ringle.
the first link is essentially this, but for a 12mm bolt through hub.
I don't have a 12mm one
Posted : 12/03/2013 9:33 pm
toppers have you used one of these kits / know someone that has?
Posted : 12/03/2013 9:34 pm
"It's to convert my NP Generator rear hub from 12mm to QR"
I meant swap the current 12mm axle actually inside your hub
Posted : 12/03/2013 9:37 pm
i have seen them but never fitted one.
if your frame has a standard qr style drop out then the axle you have ordered (if you can still get it) will convert a 12mm bolt through 135mm hub to fit your frame.
Posted : 12/03/2013 9:43 pm
Sorted. thanks.
Posted : 12/03/2013 9:49 pm
