commuting lights
[Closed] commuting lights
7 Users
i kow a lot of people on here (including me) just commute with their off roading lights, but my brother is after a front and rear set for christmas as he wants to start commuting by bike again and he needs new lights.
So...
reccomendations for reasonably (well under £30 each) priced front + rear lights please. Was thinking of getting him 2 for the back and maybe 2 for the front depending on cost so he can have one flashing and one constant.
cheers
Posted : 24/11/2009 8:50 am
[url= http://www.wiggle.co.uk/p/cycle/7/Cateye_TL_LD1100_Rear_Light/5360025767/ ]Cateye bomb[/url] for the rear. It's great and powerful, not like some rear lights that you only see when you're on top of the rider... 😕
Posted : 24/11/2009 9:09 am
 ski
I use two of these on the rear, one on constant and one flashing, very bright, the centre spot flasher can be seen from a considerable distance, this one also gives off a bit of light to the side.
btw, make sure it has the clear centre spot, as the less powerful version does not.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=42472 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=42472[/url]
Front wise, Smart do a 5 led front light, you should be able to pick up two for £30, but might be worth budgeting a bit more for a decent front light.
Posted : 24/11/2009 9:42 am
 nbt
I second the recommendation for the Holy Hand Grenade
Posted : 24/11/2009 10:12 am
The Cateeye Holy Hand Grenade can be bought in a set with a decent front light too. recommended.
Posted : 24/11/2009 10:21 am
http://www.wiggle.co.uk/p/cycle/7/Smart_5_LED_Front_and_317_Rear_Light_Set/5360026000/
Same rear light as ski links to above, they're VERY bright and it's a decent enough front as well. Great value.
Posted : 24/11/2009 10:58 am
